Date/Time: Wed, 23 Apr 2025 03:09:20 +0000
Feature request: Market Replay synchronized start
View Count: 131
[2024-12-16 22:29:55]
ElDuderino - Posts: 17
To better support trading correlated markets using multiple DOMs within the same chartbook (example: ZN, ZB, ZF Treasury futures or the ES, YM, and NQ equities index futures), please provide the ability to start multiple market replays at the same time. I can currently run three market replays on three different symbols in a the same chartbook (which is great), but it's impossible to get them all to start at the same time due to having to manually hit Play for each one in succession. My hand is fast, but not that fast!
Thanks for your time and consideration.
[2024-12-17 14:13:48]
Sébastien - Posts: 58
It already exist.
In the market replay window, you have the menu Charts to Replay.
You can select All Charts in Chartbook.
The problem still exist when doing market replay with 2 or more instances... But I think there is no solution for that.
[2024-12-17 16:16:51]
John - SC Support - Posts: 39428
Also use the "Start Paused" option when replaying multiple charts. Refer to the following:
Replaying Charts: Start Paused
