Date/Time: Sun, 04 Oct 2026 20:52:09 +0000
Question about alerts and text display for study
View Count: 629
[2024-12-16 21:39:40]
awakef - Posts: 72
Hi I managed to make a text display alert without any problems.
My question is how can I make the display alert stay for a specific seconds or minutes after it shows?
Since it stays on the full 15mins candle until the next new candle appears.
[2024-12-17 14:55:49]
John - SC Support - Posts: 48095
We need to understand what exactly you are doing. How is this alert setup, what are you doing?
[2024-12-17 15:19:14]
awakef - Posts: 72
I made an alert using text display for study exactly as your instructions with color based on alert condition to show a big text on my screen.
Text Display For Study
The alert with text display works good but after it shows it stays on until the next 15min candle appears.
I want the text display alert to show and disappear at 5min instead the text banner staying on in the screen the full 15mins duration candle.
Thanks John,
[2024-12-17 16:32:48]
If you can, you would need to set the condition in your "Color Bar Based on Alert Condition" to control this. We say "if you can", as it depends a lot on how your current condition is setup and whether you can use the Bar Times to control the time. Right now, your condition must be being reset with a new bar, which is why it is going away when a new bar starts.
Refer to the following:
Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables
[2024-12-17 22:00:48]
awakef - Posts: 72
I uploaded the settings enabled for the color bar based on alert.
Here is a example of the code I'm trying using text display alert for swing high and lows:
=OR(SG1 > 0, SG2 > 0, SG1[-1] > 0, SG2[-1] > 0, SG1[-2] > 0, SG2[-2] > 0, SG1[-3] > 0, SG2[-3] > 0)
Then I tried to use countdown timer for the text display alert dissapear at 5mins on a 15mins chart and worked good, but on the next candle keeps doing the alert when it haven't made a new swing high, low.
This is the code I made:
=OR(AND(ID41.SG1 > 0, ID41.SG2 > 0, ID41.SG1[-1] > 0, ID41.SG2[-1] > 0, ID41.SG1[-2] > 0, ID41.SG2[-2] > 0, ID41.SG1[-3] > 0, ID41.SG2[-3] > 0), AND(ID30.SG1 > 600))
There's a way that when it made the alert stays off until a real swing high, low have being made instead repeating the alert on each new candle John?
imageScreenshot 2024-12-17 162630.png / V - Attached On 2024-12-17 20:27:31 UTC - Size: 38.53 KB - 226 views
[2024-12-17 23:57:19]
You have too many AND()'s going on. Your condition should be the following:
=AND(OR(SG1 > 0, SG2 > 0, SG1[-1] > 0, SG2[-1] > 0, SG1[-2] > 0, SG2[-2] > 0, SG1[-3] > 0, SG2[-3] > 0), ID30.SG1 > 600)
Although we are not quite sure how you are using the Countdown Timer, so you may need to change the sign to a Less Than (i.e. ID30.SG1 < 600).
[2024-12-18 15:35:41]
awakef - Posts: 72
Thanks John now it worked perfectly!
Merry Christmas for you and your family!!
