Date/Time: Wed, 23 Apr 2025 03:09:22 +0000
Compability: The Chartbook file is not compatible
View Count: 118
[2024-12-16 20:57:34]
User334659 - Posts: 1
How can i resolve the following:
2024-12-16 18:54:46.853 | The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: E:\SierraChart\Data\NASDAQ.Cht *
[2024-12-16 23:12:35]
John - SC Support - Posts: 39428
Refer to the following:
Chartbooks (Workspaces): Opening Older Chartbooks
Or you can try to recover from a backup if the file is not actually older and you are just having a problem with it:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
