Date/Time: Wed, 23 Apr 2025 03:16:04 +0000
freeze laptop
View Count: 209
[2024-12-16 18:41:28] |
User344478 - Posts: 161 |
My laptop starts freezers. I use study Clock - Real Time and this watch is skipping seconds for example from 40 sec goes to 46 seconds. I use Denali.
[2024-12-17 15:20:20] |
HI DENALI FEED LAGS/FREEZE. DATA FALLING BEHIND. I CHANGE SERVERS FROM COMCAST TO AT and T, but result is not change.
[2024-12-17 19:16:33] |
Sierra_Chart Engineering - Posts: 19307 |
What symbol are you looking at?
[2024-12-17 20:45:43] |
Also refer to: Prices / Data Falling Behind To have the Countdown timer continuously update, set this Input with the Study to Yes: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=201&Name=Countdown_Timer#DisplayContinuousTimeCountdown Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-18 14:43:53] |
What symbol are you looking at? F.US.MYM
[2024-12-18 16:27:47] |
Is it the December contract or the March 2025 contract?
