Date/Time: Mon, 15 Dec 2025 09:10:57 +0000
Attaching Activity Log to main window
View Count: 414
[2024-12-16 17:12:53]
xORDERBOOKx - Posts: 191
Is there any way to attach the Activity Log to the main Sierra Chart window?
If I minimize/maximize the main window I have to close and then re-open the Activity Log if I want it to go away. Being able to attach this to the main window, like every other window, would be ideal.
I can't find anything in the documentation to do this. Is there any way to make this work?
Thank you.
[2024-12-16 19:30:11]
John - SC Support - Posts: 43443
There is not a way to do this. The Trade Activity Log is always a separate window.
[2024-12-16 20:03:04]
Ok, thanks. Can I ask why?
[2024-12-16 23:07:30]
To be perfectly blunt - I do not know. It was how that window was designed at the time. I'm sure there was some reason for it, but I just do not know what it was.
[2025-02-01 04:16:29]
kenjo - Posts: 9
Could you guys make it a feature to be able to attach the Trade Activity Log to the main window? I'm used to having a small window showing my filled orders while trading.
[2025-02-01 19:09:29]
Sierra_Chart Engineering - Posts: 21843
We could make it in owned type window. It would certainly overlap the main window but it would be on top of it.
[2025-02-01 19:41:43]
kenjo - Posts: 9
That would work just fine, thank you!
[2025-02-03 00:22:53]
kenjo - Posts: 9
Just realized i could make window type "Always on Top". that works aswell
[2025-02-03 00:28:42]
Yes.
