Date/Time: Wed, 23 Apr 2025 03:19:24 +0000
[Trading Evaluator - Delayed] only executes on even seconds
View Count: 127
[2024-12-16 16:11:16] |
ATEX - Posts: 25 |
Hi, I have forward tested a system using the Trading Evaluator - Delayed service. When I study the trades I notice that all trades are executed on even seconds, with no millisecond resolution: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=111586 When I backtest the same system with detailed replay, I get millisecond resolution: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=111587 I wonder what may be the cause of this. Thank you! |
![]() Attachment Deleted. ![]() |
[2024-12-16 18:41:12] |
Sierra_Chart Engineering - Posts: 19307 |
We do see this is the case for historical order fills downloaded from the Trading Evaluator services. We will see if we can provide the microsecond resolution.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-16 18:42:02
