Date/Time: Wed, 23 Apr 2025 03:12:53 +0000
[User Discussion] - Quote Board highlighting multiple symbols
View Count: 183
[2024-12-16 15:34:17]
User353369 - Posts: 17
I have had an issue for a while on multiple SC versions where the quote board will highlight multiple symbols or sometime the entire symbol column either by itself or if the mouse crosses over the QB without pausing or clicking. The symbols highlight in an orangish color not seen in the high/low alert. No symbols should ever be highlighted as far as I can tell from my setting. Any thoughts help appreciated.
BT
[2024-12-16 18:46:04]
John - SC Support - Posts: 39428
The symbol will be highlighted for the selected row. Or, if the option for "Settings >> Highlight All Fields" is selected, then the entire row will be highlighted when it is selected. It is also possible to select multiple rows using Ctrl-Click or Shift-click.
But, this highlighting should not be occurring if you are not actually clicking in the Quote Board. It sounds like this may be an operating system issue, or perhaps something about a particular OS setting.
Just so you are aware, the color of the highlighting is defined at the following:
https://www.sierrachart.com/QuoteBoard_SelectedSymbol
[2024-12-16 18:54:45]
Thanks,
[2024-12-16 18:54:57]
Thanks,
