Date/Time: Wed, 23 Apr 2025 03:16:05 +0000
Getting [volume] symbol needs rollover
View Count: 191
[2024-12-16 14:56:05] |
cuckiecheese - Posts: 75 |
I'm using ES symbol, and i'm getting a message that says [volume] symbol needs rollover, however, I'm using date rule rollover for all the charts in the chartbook, and the symbols should not be rolling over next session (per my symbol settings). What gives? Thanks |
[2024-12-16 18:33:01] |
John - SC Support - Posts: 39428 |
The fact that it states "Volume" in the rollover message means that you have the following option set to "Yes". You should change it to "No": General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-16 18:39:55] |
TY
