Date/Time: Wed, 23 Apr 2025 03:09:24 +0000
Limiting the number of tick information for order flow footprint charts
View Count: 156
[2024-12-16 13:53:25] |
User810128 - Posts: 3 |
Hello, I am on an order flow footprint chart that displays information for every tick. Is it possible to limit the information displayed to multiple times more than one tick. I am hoping to save some screen real estate. Pictures attached for some visual examples, in case I'm being confusing with my description. One picture is the standard order flow footprint chart and the other is the same chart with what appears to be a modified, more streamlined footprint chart. https://imgur.com/a/lQIqdhK |
![]() Attachment Deleted. |
[2024-12-16 18:30:28] |
John - SC Support - Posts: 39428 |
Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
