Date/Time: Wed, 23 Apr 2025 03:16:02 +0000
Macd 2 lines with volumes
View Count: 110
[2024-12-16 13:36:28]
CharlieCee - Posts: 5
What is the study and the configuration to use macd 2 lines and volume with 250 tick bar graph ?
I used to use it in ninja, but I don't know how it work here.
Thanks a lot
[2024-12-16 18:11:46]
John - SC Support - Posts: 39428
We are not sure what you are referring to. There are several MACD studies. You will find them all listed in the following section:
Technical Studies Reference
