Date/Time: Wed, 23 Apr 2025 03:19:23 +0000
Trade Statistics in ACSIL
View Count: 186
[2024-12-15 18:01:20] |
User081362 - Posts: 8 |
Hello, I can't seem to find a function to retrieve the total trades on an account. I found one that retrieves them for the day but I need total of all time. I currently have a code built that exports to a csv but it is over-complicated for what I need. Objective is to get the win rate for my bot. Any help is appreciated. |
[2024-12-16 06:57:25] |
Sierra_Chart Engineering - Posts: 19307 |
You need to set the chart to load the order fills required.: Chart Settings: Trading And then use this function: ACSIL Interface Members - Functions: sc.GetTradeStatisticsForSymbolV2() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-16 06:58:14
