Date/Time: Mon, 15 Dec 2025 09:28:33 +0000
sc.FirstCallToFunction
View Count: 243
| [2024-12-15 14:22:41] |
| seandunaway - Posts: 360 |
boolean sc.FirstCallToFunction would be saweet
| [2024-12-15 19:31:15] |
| Sierra_Chart Engineering - Posts: 21843 |
You are able to implement this yourself through persistent variables: ACSIL Interface Members - Functions: Persistent Variable Functions Set a variable to 1 indicating the first time the study function instance is called. And if that variable is already set to 1, then you know that it is a subsequent function call. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-15 19:33:11
