Date/Time: Sun, 27 Sep 2026 07:48:27 +0000
Copy setup to Laptop
View Count: 1323
[2014-09-13 23:36:23]
User57562 - Posts: 98
On desktop, SC working nicely, saved chartbook with QuoteBoard and WatchList both linked to two chart frames.
Installed Sierra on Laptop, copied some files from desktop, running in minutes. Great! Good programming.
Loaded the saved chartbook. QB updates symbol in both chart frames.
WatchList only updates the first active frame. Switching frames does not make WL update symbol.
Closing and making new watchlist, importing symbol list, same incomplete results.
Should I just use QB and drop WL? Also, QB can minimize but WL cannot, further suggesting I ignore WL.
I'm puzzled why two PCs show slightly different behavior.
NOTE: the whole migration and operation are much better than for program I had used on stocks. Yay team!
[2014-09-17 00:30:49]
This we are not understanding.
[2014-09-17 17:04:06]
If you are using chart linking for the charts and Quote Board, it may not be set correctly. Refer to the documentation about this here:
Working With Charts: Chart Linking
Getting Quotes: Changing Symbol of a Chart or Trade DOM
Date Time Of Last Edit: 2014-09-17 17:04:31
