Date/Time: Wed, 23 Apr 2025 03:16:04 +0000
Margin requirements
View Count: 200
[2024-12-14 21:39:41]
linusb - Posts: 1
Is it possible to avoid the higher margin requirements of Sierra by using a broker like Tradovate with lower margin requirements for ES/NQ (intraday)?
Thanks in advance
[2024-12-15 01:25:25]
Sierra_Chart Engineering - Posts: 19307
Sierra Chart does not set margin requirements. These are controlled by the broker. Check with the different brokers and find out what their margin requirements are.
Also Sierra Chart does not support Tradovate.
We recommend using Teton order routing:
Sierra Chart Teton Futures Order Routing: Setup Instructions
