Date/Time: Wed, 23 Apr 2025 03:16:02 +0000
Volume at Price Threshold Alert V2- How not to extend line
View Count: 145
[2024-12-14 17:40:25]
Kifutures - Posts: 6
Good day!
1)I would like to know if there is any way to not extend the line on Volume at Price Threshold Alert V2.
I would like the line to display till the next bar.
2)On different note regarding Auto Retracement/Projection studies, I've noticed the Time Period Unit in the settings and inputs doesn't have options for range bar.
I would like to display 0.25 and 0.75 point on a 50range bar.
Any advice on the above two matters will be very much appreciated.
Date Time Of Last Edit: 2024-12-15 09:37:43
[2024-12-16 14:56:29]
John - SC Support - Posts: 39428
1) There is no option to only display the Extension Line until the next bar. It only draws until an intersection with another bar, or to the end of the chart.
2) The Time Period settings are used to set the length of time over which the Retracement/Projection will occur and then resets at each particular time interval.
The Level x Percentages define the percentage values that are used to define the levels of the lines.
It doesn't sound like the Auto Retracement/Projection study is what are wanting. If you want to have a line drawn at 25% and 75% of the price range of each bar, then use two copies of the "Spreadsheet Formula" study and enter the following for the 25% condition:
=((H - L) * .25) + L
Set the "Draw Style" for the subgraph of the study to be "Dash" in order to get the line just drawn for each bar. Refer to the following:
Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables
Spreadsheet Formula
Date Time Of Last Edit: 2024-12-16 14:57:01
[2024-12-17 06:05:16]
As always, thank you for the help!
