Date/Time: Mon, 15 Dec 2025 09:10:58 +0000
Color bar based on alert condition
View Count: 406
[2024-12-13 18:06:43]
MarketBeast - Posts: 47
Hello SC Team,
How can I apply the "Color Bar Based On Alert Condition" study on a "TICK" chart? It seems to be working fine on time based chart but doesn't work on a 5000 intraday tick chart. Any suggestions? Can I overlay study in this case? Please advise.
[2024-12-13 18:07:31]
John - SC Support - Posts: 43443
The "Color Bar Based on Alert Condition" will work on a "Number of Trades" chart. If you are not getting what you expect, then most likely this has something to do with your alert condition.
[2024-12-13 22:01:32]
Hello John,
I'm using 2 studies "Ask/Bid Volume Difference Bars" and "Cumulative Delta Bars-Volume". ID.3 and ID.2
I want to color the bar when there is a new consecutive higher high in both of the studies.
The "Output When Condition True" is set to "Use Input Data"
My alert condition code is
=AND(ID2.SG2 > ID2.SG2, ID3.SG2 > ID3.SG2)
SG2 is for the "High" pretty sure I'm missing something to get the higher high.
Date Time Of Last Edit: 2024-12-14 01:28:01
[2024-12-16 14:32:31]
You are checking a bar against itself. If you want to test against the previous bar, then you need to use a [-1] modifier, so your condition would be the following:
=AND(ID2.SG2 > ID2.SG2[-1], ID3.SG2 > ID3.SG2[-1])
Refer to the following:
Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart
