Date/Time: Wed, 23 Apr 2025 03:09:23 +0000
Version 2720 has no Borders
View Count: 205
[2024-12-13 15:27:53] |
User986474 - Posts: 35 |
The new version 2720 has no borders between the studies on the chart. Can this be fixed?
[2024-12-13 15:46:24] |
John - SC Support - Posts: 39428 |
Refer to the following: Chart Settings: Display Region Dividing Lines (Chart >> Chart Settings >> Grid menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-13 17:26:11] |
The region dividing lines still do not show up in version 2720, even after confirming they are on in Chart Settings and making sure the color is set to black.
[2024-12-13 18:03:18] |
Please update to the latest Pre-Release (v 2721) and if you are still having a problem then please get us an image of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-14 18:57:45] |
Sierra_Chart Engineering - Posts: 19307 |
Nothing has changed with this and we do not observe any problem with this.
