Date/Time: Wed, 23 Apr 2025 03:09:20 +0000
Colors for DOM and Chart Trading Orders
View Count: 128
[2024-12-13 13:46:07]
nicktrader - Posts: 748
I was able to adjust the colors of the “Chart Trading Orders” as desired.
But I search in vain for the same color combination for the DOM orders (pls see pic).
Many thanks
imageLimit and Child Orders.png / V - Attached On 2024-12-13 13:45:56 UTC - Size: 94.43 KB - 41 views
[2024-12-13 14:48:38]
John - SC Support - Posts: 39428
The colors you changed for the "Chart Trading Orders..." apply to both the Charts and Trading DOMs. There are no separate items for the chart and for the Trading DOM.
If you are not getting the same colors in the Trading DOM, then one of the items is using Chart specific graphics instead of the global graphics. Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
Also note the "Copy From/To Global" buttons defined in this section:
Graphics Settings: Graphics Settings Controls
[2024-12-13 15:06:11]
Many thanks John. The “Use global graphics...” checkbox is off...
