Date/Time: Wed, 23 Apr 2025 03:12:52 +0000
The TTM Squeeze Indicator
View Count: 268
[2024-12-13 11:24:44] |
natanibz - Posts: 140 |
Hello, is there the TTM Squeeze Indicator or a similar indicator in SC ? Thanks Is Bollinger Squeeze the same indicator? Date Time Of Last Edit: 2024-12-13 11:29:52
[2024-12-13 14:38:21] |
John - SC Support - Posts: 39428 |
All of our studies are listed at the following link: Technical Studies Reference And all of them have the math for how they are calculated in them. Therefore, you can look through and see how we calculate the Bollinger Squeeze studies we have and see if they are what you are looking for, as well as looking to see if there is something else that comes close. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-13 17:50:32] |
User708541 - Posts: 135 |
Sierra has the Squeeze indicator. Go to Add Custom Studies and it's there. See image. |
