Date/Time: Wed, 23 Apr 2025 03:16:02 +0000
Replay Funtion
View Count: 115
[2024-12-13 11:03:56] |
Tin43 - Posts: 141 |
I'was wondering if it is possible to do this: Imagine I replay to date 06/24/2024 at 9:30. And test what i want in a period of 5 minutes. So I will end at 9:35. Now I want to go to the next day 06/25/2024 at the same time, 9:30. It's possible to do this without speeding the replay function?¿ Something like "go to Date" but with the replay functionality? |
[2024-12-13 14:36:14] |
John - SC Support - Posts: 39428 |
There is not a way to do this directly. The closest option is the "Jump" capability of the Replay using the "By Time" option. But it will only get you close, not exact. Refer to the following: Replaying Charts: Jump For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
