Date/Time: Mon, 15 Dec 2025 09:09:40 +0000
Pivot Points - Variable Period Not Plotting R5, S5 Lines
View Count: 1965
| [2014-09-12 20:32:41] |
| cmet - Posts: 721 |
On the Variable Period Pivots the lines for S5 and R5 do not show up. I'm using 30 minute pivots and the levels are both using Dash > Solid > 1px. Everything else plots. Would also be nice to have R 4.5 and S 4.5 levels included in this indicator. Here it is on a 1 min chart: http://postimg.org/image/wy8lyj0dp/ |
| [2014-09-13 03:54:30] |
What this means is the particular Formula Type input setting you are using, does not have these levels. What Formula Type are you using? And what would be the calculation method for these levels? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-09-13 13:05:12] |
| cmet - Posts: 721 |
Okay, I understand now. Thank you. |
| [2014-09-13 15:50:53] |
We can easily enough add the levels, we just need to know what particular formula type it is and the calculation method.
| [2014-09-13 17:41:59] |
| cmet - Posts: 721 |
The standard pivot calculation - #0 I use these on 30 min intervals and moves to the 4 and 5 levels are not common but ranges usually max out near those levels. Would be nice to have them if it's easy to implement. |
| [2014-09-15 19:48:02] |
The fifth level Support and Resistance lines for Formula Type 0 will be added to the next release.
| [2023-03-15 12:43:23] |
| User652903 - Posts: 25 |
Can you please add support for extended pivot lines (5-8) to formula #8 in the next release? Thank you
| [2023-03-15 15:55:05] |
| John - SC Support - Posts: 43443 |
What are the formulas for the additional pivot lines for Formula #8?
