Date/Time: Wed, 27 Nov 2024 14:25:49 +0000
Sierra Chart Real-time Exchange Data feed question
View Count: 980
[2014-09-12 20:11:34] |
User626121 - Posts: 82 |
Hi SC Engineering, I'm interested in the SC Realtime data feed. Specifically I need realtime data for CME Clearport OTC Energy products like Singapore Fuel Oil 380 cst (Platts) Futures (symbol SE) or Gulf Coast No. 6 Fuel Oil 3.0% (Platts) Futures (symbol MF). Also the Clearport data for the NYMEX/Globex traded symbols like CL, HO, RB (incl. blocktrades). Also it would be nice if floor data was included (not a must). Is this data included in the Full CME Group data feed? Thanks in advance Date Time Of Last Edit: 2014-09-12 20:20:16
[2014-09-12 22:06:18] |
We have to check on this, but at this point, this data is not included and we recommend using another data feed that provides the symbols you are looking for. We do not know if this data can be added. If they can be, it requires some work to provide.
