Date/Time: Mon, 15 Dec 2025 09:09:44 +0000
configuration file errors
View Count: 466
| [2024-12-12 16:14:25] |
| User785536 - Posts: 11 |
i am receiving the following configuration file error: "Not enough data in the configuration file to be valid" |
| [2024-12-12 17:38:51] |
| John - SC Support - Posts: 43443 |
Where exactly are you seeing this message? If it is in a log file, then please get us a few lines above and below that error and copy and paste them to this thread. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-12-12 19:00:29] |
| Sierra_Chart Engineering - Posts: 21843 |
There is a problem with one of the configuration files or some file access issue. Follow the instructions here to restore one from a backup: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-12 19:01:00
| [2024-12-12 19:44:25] |
I will try this. I also received the “Error connecting to Data or Trading service. For help with this issue, press the ‘send for analysis’ button… I am informing you before I do so
| [2024-12-12 20:12:40] |
What trading service are you trying to connect to (what is "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" set to)? Are you getting any other error about a connection problem? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-12-12 22:37:45] |
It was a log file, but now I am not receiving it. I was trying to connect to rithmic. A message did pop up before but now it just gets stuck at connecting. Then I tried SC Data - All Services and charts are hours behind and not moving. Inam getting the error, +error reading record for update intraday chart…
| [2024-12-12 23:22:30] |
We need to see your Message Log. Please follow these instructions to get us your Message Log: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-12-12 23:48:18] |
2024-12-12 23:43:35.002 | Trade activity files set size: 74 2024-12-12 23:43:35.204 | Reading Internal Order ID file. 2024-12-12 23:43:35.232 | Reading Trade Orders file. 2024-12-12 23:43:35.233 | Reading Trade Positions file. 2024-12-12 23:43:35.233 | Reading Trade Account Data files. 2024-12-12 23:43:35.239 | Software version: 2715 64-bit 2024-12-12 23:43:35.239 | Primary Thread ID: 13820 2024-12-12 23:43:35.239 | Usage end date: 2024-12-31 2024-12-12 23:43:35.239 | Enabled for: Advanced Features 2. 2024-12-12 23:43:35.239 | Enabled for: Sierra Chart Historical Data Service. 2024-12-12 23:43:35.239 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-12-12 23:43:35.239 | Enabled for: Delayed Denali Exchange Data Feed. 2024-12-12 23:43:35.239 | Enabled for exchange2: CME 2024-12-12 23:43:35.239 | Enabled for exchange2: US Equities Consolidated Tape 2024-12-12 23:43:35.239 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-12-12 23:43:35.239 | Current selected Data/Trading service: SC Data - All Services 2024-12-12 23:43:35.239 | Custom symbol settings values: enabled 2024-12-12 23:43:35.239 | Chart Update Interval: 400 2024-12-12 23:43:35.239 | Intraday Data Storage Time Unit: 1 2024-12-12 23:43:35.239 | Time Zone: +00:00:00 (UTC+00) 2024-12-12 23:43:35.239 | 2024-12-12 23:43:35 Local computer time in UTC 2024-12-12 23:43:35.239 | 2024-12-12 23:43:35 Local computer time in SC Time Zone 2024-12-12 23:43:35.239 | 2024-12-12 23:43:33 Server time in UTC 2024-12-12 23:43:35.239 | Local computer UTC time and Server UTC time difference: 1 seconds. 2024-12-12 23:43:35.239 | Program path: C:\SierraChart\ 2024-12-12 23:43:35.239 | Data Files path: C:\SierraChart\Data\ 2024-12-12 23:43:35.240 | OS Version Number: 10.0 2024-12-12 23:43:35.240 | Locale Setting: C 2024-12-12 23:43:35.240 | DLLs: UserContributedStudies_64.dll 2024-12-12 23:43:35.240 | Allowed protected custom studies: 2024-12-12 23:43:35.240 | Crash reporter started: true 2024-12-12 23:43:35.240 | 2024-12-12 23:43:35.306 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. 2024-12-12 23:43:35.308 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:43:35.380 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-12-12 23:43:35.380 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-12-12 23:43:35.573 | Received 5 login tokens. 2024-12-12 23:43:36.106 | Symbol settings MD5 received. Request ID: 1. 2024-12-12 23:43:36.106 | Symbol settings are up-to-date for scdataallservices. 2024-12-12 23:43:37.820 | Requested user files to download. 2024-12-12 23:43:39.824 | 2024-12-12 23:43:39.824 | SC Data - All Services | Connected to server complete. 2024-12-12 23:43:39.824 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-12-12 23:43:43.053 | Files to Open on Startup | Opening file: ExampleChartbook.cht 2024-12-12 23:43:43.087 | NQZ4.CME 5000 Volume #12 | Reloading chart. 2024-12-12 23:43:43.528 | NQZ4.CME 2 Min #1 | Reloading chart. 2024-12-12 23:43:43.555 | nqZ4.CME #2 | Reloading chart. 2024-12-12 23:43:43.644 | ESZ4.CME 5000 Volume #3 | Reloading chart. 2024-12-12 23:43:43.696 | NQZ4.CME #4 | Reloading chart. 2024-12-12 23:43:43.767 | Using symbol data fast lookup vector 2024-12-12 23:43:43.769 | SC Data - All Services | Starting real-time market data updates for: NQZ4.CME. ID: 1 2024-12-12 23:43:43.769 | SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NQZ4.CME 2024-12-12 23:43:43.769 | SC Data - All Services | Requesting security definition data for: NQZ4.CME. ID: 1 2024-12-12 23:43:43.769 | No historical data client is currently set to download historical Intraday data for NQZ4.CME. 2024-12-12 23:43:43.769 | Real-time Intraday chart data file updates started for NQZ4.CME 2024-12-12 23:43:43.770 | Opened cached Intraday file: C:\SierraChart\Data\NQZ4.CME.scid. Thread ID: 13820 2024-12-12 23:43:43.770 | Intraday chart data file opened for NQZ4.CME 2024-12-12 23:43:43.775 | nqZ4.CME #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\nqZ4.CME.scid 2024-12-12 23:43:43.775 | nqZ4.CME #2 | Chart data loading complete. 2024-12-12 23:43:43.784 | No historical data client is currently set to download historical Intraday data for NQZ4.CME. 2024-12-12 23:43:43.784 | Real-time Intraday chart data file updates started for NQZ4.CME 2024-12-12 23:43:43.786 | Opened cached Intraday file: C:\SierraChart\Data\NQZ4.CME.scid. Thread ID: 13820 2024-12-12 23:43:43.786 | Intraday chart data file opened for NQZ4.CME 2024-12-12 23:43:43.949 | No historical data client is currently set to download historical Intraday data for NQZ4.CME. 2024-12-12 23:43:43.949 | Real-time Intraday chart data file updates started for NQZ4.CME 2024-12-12 23:43:43.950 | Opened cached Intraday file: C:\SierraChart\Data\NQZ4.CME.scid. Thread ID: 13820 2024-12-12 23:43:43.950 | Intraday chart data file opened for NQZ4.CME 2024-12-12 23:43:43.961 | No historical data client is currently set to download historical Intraday data for NQZ4.CME. 2024-12-12 23:43:43.961 | Real-time Intraday chart data file updates started for NQZ4.CME 2024-12-12 23:43:43.962 | Opened cached Intraday file: C:\SierraChart\Data\NQZ4.CME.scid. Thread ID: 13820 2024-12-12 23:43:43.962 | Intraday chart data file opened for NQZ4.CME 2024-12-12 23:43:44.053 | SC Data - All Services | Starting real-time market data updates for: ESZ4.CME. ID: 2 2024-12-12 23:43:44.053 | SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESZ4.CME 2024-12-12 23:43:44.053 | SC Data - All Services | Requesting security definition data for: ESZ4.CME. ID: 2 2024-12-12 23:43:44.053 | No historical data client is currently set to download historical Intraday data for ESZ4.CME. 2024-12-12 23:43:44.053 | Real-time Intraday chart data file updates started for ESZ4.CME 2024-12-12 23:43:44.054 | Opened cached Intraday file: C:\SierraChart\Data\ESZ4.CME.scid. Thread ID: 13820 2024-12-12 23:43:44.054 | Intraday chart data file opened for ESZ4.CME 2024-12-12 23:43:44.336 | No historical data client is currently set to download historical Intraday data for NQZ4.CME. 2024-12-12 23:43:44.336 | Real-time Intraday chart data file updates started for NQZ4.CME 2024-12-12 23:43:44.336 | Opened cached Intraday file: C:\SierraChart\Data\NQZ4.CME.scid. Thread ID: 13820 2024-12-12 23:43:44.336 | Intraday chart data file opened for NQZ4.CME 2024-12-12 23:43:44.458 | No historical data client is currently set to download historical Intraday data for ESZ4.CME. 2024-12-12 23:43:44.458 | Real-time Intraday chart data file updates started for ESZ4.CME 2024-12-12 23:43:44.459 | Opened cached Intraday file: C:\SierraChart\Data\ESZ4.CME.scid. Thread ID: 13820 2024-12-12 23:43:44.459 | Intraday chart data file opened for ESZ4.CME 2024-12-12 23:43:44.677 | NQZ4.CME #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:43:44.679 | NQZ4.CME #4 | Chart data loading complete. 2024-12-12 23:43:44.830 | Requesting market depth updates for: NQZ4.CME if supported. NumLevels=1400 2024-12-12 23:43:44.830 | Separate subscription for market depth updates not supported. NQZ4.CME 2024-12-12 23:43:45.190 | NQZ4.CME 5000 Volume #12 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:43:45.198 | NQZ4.CME 5000 Volume #12 | Chart data loading complete. 2024-12-12 23:43:45.492 | NQZ4.CME 2 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:43:45.578 | NQZ4.CME 2 Min #1 | Chart data loading complete. 2024-12-12 23:43:46.643 | ESZ4.CME 5000 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:43:46.731 | ESZ4.CME 5000 Volume #3 | Chart data loading complete. 2024-12-12 23:45:50.908 | SC Data - All Services | Disconnected. | Number times message added: 1 2024-12-12 23:45:50.910 | Rithmic Direct - DTC | Processed connection points. Count: 347 2024-12-12 23:45:50.962 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 2. 2024-12-12 23:45:50.962 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-12-12 23:45:50.970 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. 2024-12-12 23:45:50.970 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | New receive buffer size: 0 2024-12-12 23:45:50.970 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Connecting to IP: 216.66.0.130. 2024-12-12 23:45:51.505 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131 2024-12-12 23:45:51.506 | Rithmic Direct - DTC | Processed connection points. Count: 347 2024-12-12 23:45:51.634 | Symbol settings MD5 received. Request ID: 2. 2024-12-12 23:45:51.634 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 3. 2024-12-12 23:45:51.745 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | CloseSocket call. 2024-12-12 23:45:51.745 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:45:51.830 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-12-12 23:45:51.830 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Closed. 2024-12-12 23:45:52.541 | Symbol settings received. Request ID: 3. 2024-12-12 23:45:53.010 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:45:56.993 | 2024-12-12 23:45:56.993 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated 2024-12-12 23:45:56.993 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500 2024-12-12 23:45:56.996 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 2024-12-12 23:45:57.020 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-12-12 23:45:57.020 | DTC Client socket (1) | New receive buffer size: 0 2024-12-12 23:45:57.020 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-12-12 23:45:57.088 | Rithmic Direct - DTC | Network connection to server complete. 2024-12-12 23:45:57.088 | Rithmic Direct - DTC | Starting socket receive thread. 2024-12-12 23:45:57.088 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-12-12 23:45:57.089 | Rithmic Direct - DTC | Sending logon request message. 2024-12-12 23:45:57.329 | Rithmic Direct - DTC | Received logon response. 2024-12-12 23:45:57.329 | Rithmic Direct - DTC | Server Name: . 2024-12-12 23:45:57.329 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-12-12 23:45:57.329 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-12-12 23:45:57.329 | Rithmic Direct - DTC | Failed connections: 1 2024-12-12 23:45:57.329 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-12-12 23:45:57.329 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:45:57.450 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-12-12 23:45:57.451 | DTC Client socket (1) | CloseSocket call. 2024-12-12 23:45:57.451 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:45:57.451 | Rithmic Direct - DTC | Disconnected. 2024-12-12 23:45:57.451 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:45:57.535 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:45:57.535 | DTC Client socket (1) | Closed. 2024-12-12 23:46:01.458 | 2024-12-12 23:46:01.458 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated 2024-12-12 23:46:01.458 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500 2024-12-12 23:46:01.458 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 2024-12-12 23:46:01.460 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-12-12 23:46:01.460 | DTC Client socket (1) | New receive buffer size: 0 2024-12-12 23:46:01.460 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-12-12 23:46:01.745 | Rithmic Direct - DTC | Network connection to server complete. 2024-12-12 23:46:01.745 | Rithmic Direct - DTC | Starting socket receive thread. 2024-12-12 23:46:01.745 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-12-12 23:46:01.745 | Rithmic Direct - DTC | Sending logon request message. 2024-12-12 23:46:02.227 | Rithmic Direct - DTC | Received logon response. 2024-12-12 23:46:02.227 | Rithmic Direct - DTC | Server Name: . 2024-12-12 23:46:02.227 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-12-12 23:46:02.227 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-12-12 23:46:02.227 | Rithmic Direct - DTC | Failed connections: 2 2024-12-12 23:46:02.227 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-12-12 23:46:02.227 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:02.242 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-12-12 23:46:02.243 | DTC Client socket (1) | CloseSocket call. 2024-12-12 23:46:02.243 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:46:02.243 | Rithmic Direct - DTC | Disconnected. 2024-12-12 23:46:02.243 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:02.433 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:46:02.433 | DTC Client socket (1) | Closed. 2024-12-12 23:46:06.252 | 2024-12-12 23:46:06.252 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated 2024-12-12 23:46:06.252 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500 2024-12-12 23:46:06.252 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 2024-12-12 23:46:07.369 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-12-12 23:46:07.369 | DTC Client socket (1) | New receive buffer size: 0 2024-12-12 23:46:07.369 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-12-12 23:46:07.445 | Rithmic Direct - DTC | Network connection to server complete. 2024-12-12 23:46:07.445 | Rithmic Direct - DTC | Starting socket receive thread. 2024-12-12 23:46:07.445 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-12-12 23:46:07.445 | Rithmic Direct - DTC | Sending logon request message. 2024-12-12 23:46:07.680 | Rithmic Direct - DTC | Received logon response. 2024-12-12 23:46:07.680 | Rithmic Direct - DTC | Server Name: . 2024-12-12 23:46:07.680 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-12-12 23:46:07.680 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-12-12 23:46:07.680 | Rithmic Direct - DTC | Failed connections: 3 2024-12-12 23:46:07.680 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-12-12 23:46:07.680 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:07.691 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-12-12 23:46:07.692 | DTC Client socket (1) | CloseSocket call. 2024-12-12 23:46:07.692 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:46:07.692 | Rithmic Direct - DTC | Disconnected. 2024-12-12 23:46:07.692 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:07.775 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:46:07.775 | DTC Client socket (1) | Closed. 2024-12-12 23:46:11.690 | 2024-12-12 23:46:11.690 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated 2024-12-12 23:46:11.690 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500 2024-12-12 23:46:11.690 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 2024-12-12 23:46:11.698 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-12-12 23:46:11.698 | DTC Client socket (1) | New receive buffer size: 0 2024-12-12 23:46:11.698 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-12-12 23:46:11.837 | Rithmic Direct - DTC | Network connection to server complete. 2024-12-12 23:46:11.837 | Rithmic Direct - DTC | Starting socket receive thread. 2024-12-12 23:46:11.837 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-12-12 23:46:11.838 | Rithmic Direct - DTC | Sending logon request message. 2024-12-12 23:46:12.077 | Rithmic Direct - DTC | Received logon response. 2024-12-12 23:46:12.077 | Rithmic Direct - DTC | Server Name: . 2024-12-12 23:46:12.077 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-12-12 23:46:12.077 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-12-12 23:46:12.077 | Rithmic Direct - DTC | Failed connections: 4 2024-12-12 23:46:12.077 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-12-12 23:46:12.077 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:12.089 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-12-12 23:46:12.090 | DTC Client socket (1) | CloseSocket call. 2024-12-12 23:46:12.090 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:46:12.090 | Rithmic Direct - DTC | Disconnected. 2024-12-12 23:46:12.091 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:12.194 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:46:12.194 | DTC Client socket (1) | Closed. 2024-12-12 23:46:16.089 | 2024-12-12 23:46:16.090 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated 2024-12-12 23:46:16.090 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500 2024-12-12 23:46:16.090 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 2024-12-12 23:46:16.091 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-12-12 23:46:16.092 | DTC Client socket (1) | New receive buffer size: 0 2024-12-12 23:46:16.092 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-12-12 23:46:16.171 | Rithmic Direct - DTC | Network connection to server complete. 2024-12-12 23:46:16.171 | Rithmic Direct - DTC | Starting socket receive thread. 2024-12-12 23:46:16.171 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-12-12 23:46:16.171 | Rithmic Direct - DTC | Sending logon request message. 2024-12-12 23:46:16.404 | Rithmic Direct - DTC | Received logon response. 2024-12-12 23:46:16.404 | Rithmic Direct - DTC | Server Name: . 2024-12-12 23:46:16.404 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-12-12 23:46:16.404 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-12-12 23:46:16.404 | Rithmic Direct - DTC | Failed connections: 5 2024-12-12 23:46:16.404 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-12-12 23:46:16.404 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:16.491 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-12-12 23:46:16.492 | DTC Client socket (1) | CloseSocket call. 2024-12-12 23:46:16.492 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:46:16.492 | Rithmic Direct - DTC | Disconnected. 2024-12-12 23:46:16.492 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:16.573 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:46:16.573 | DTC Client socket (1) | Closed. 2024-12-12 23:46:19.830 | File >> Disconnect selected. 2024-12-12 23:46:19.831 | DTC Client socket (0) | CloseSocket call. 2024-12-12 23:46:19.831 | Rithmic Direct - DTC | Disconnected. 2024-12-12 23:46:36.102 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. 2024-12-12 23:46:36.102 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 0 2024-12-12 23:46:36.102 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 216.66.0.130. 2024-12-12 23:46:36.582 | Rithmic Direct - DTC | HTTP response receiving connection points not completed or OK. 2024-12-12 23:46:36.582 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | CloseSocket call. 2024-12-12 23:46:36.582 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:46:36.669 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. 2024-12-12 23:46:36.669 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Closed. 2024-12-12 23:46:36.677 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 4. 2024-12-12 23:46:36.677 | Current selected Data/Trading service: Teton CME Order Routing 2024-12-12 23:46:37.412 | Symbol settings MD5 received. Request ID: 4. 2024-12-12 23:46:37.413 | Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 5. 2024-12-12 23:46:38.177 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:46:38.256 | NQZ24_FUT_CME #4 | Reloading chart. 2024-12-12 23:46:38.286 | Mapping NQZ24_FUT_CME to NQZ24. Service code: cme 2024-12-12 23:46:38.286 | Starting DelayedDownloadMonitoringTimer 2024-12-12 23:46:38.286 | Starting HDTimeoutTimer 2024-12-12 23:46:38.287 | Added historical Intraday data request for NQZ24_FUT_CME to the queue. 2024-12-12 23:46:38.287 | Intraday data recording state for symbol NQZ24_FUT_CME is set to download 'Pending'. 2024-12-12 23:46:38.290 | Triggering next historical data download in queue. 2024-12-12 23:46:38.301 | HD Request # 1 | Downloading Intraday chart data for NQZ24_FUT_CME to the file NQZ24_FUT_CME.scid. Service: cme 2024-12-12 23:46:38.328 | HD Request # 1 | Download start date-time: 2024-12-12 21:59:59.000000. File last date-time: 2024-12-12 21:59:59.188000 2024-12-12 23:46:38.328 | HD Request # 1 | Using server: ds28.sierracharts.com port 10150 2024-12-12 23:46:38.329 | Socket (1) | Creating socket. 2024-12-12 23:46:38.329 | Socket (1) | New receive buffer size: 0 2024-12-12 23:46:38.329 | Socket (1) | Connecting to IP: 67.214.125.5. 2024-12-12 23:46:38.444 | Symbol settings received. Request ID: 5. 2024-12-12 23:46:38.643 | NQZ24_FUT_CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:46:38.645 | NQZ24_FUT_CME[M] #4 | Chart data loading complete. 2024-12-12 23:46:38.648 | NQZ24_FUT_CME 5000 Volume #12 | Reloading chart. 2024-12-12 23:46:38.656 | NQZ24_FUT_CME 2 Min #1 | Reloading chart. 2024-12-12 23:46:38.667 | NQZ24_FUT_CME #2 | Reloading chart. 2024-12-12 23:46:38.671 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-12-12 23:46:38.671 | HD Request # 1 | Sending historical data logon request message. 2024-12-12 23:46:38.700 | ESZ24_FUT_CME 5000 Volume #3 | Reloading chart. 2024-12-12 23:46:38.844 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-12-12 21:59:59. Record interval: 1. Symbol: NQZ24 2024-12-12 23:46:38.954 | HD Request # 1 | Decompressing data. 2024-12-12 23:46:39.056 | ESZ24_FUT_CME 5000 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:46:39.161 | ESZ24_FUT_CME 5000 Volume #3 | Chart data loading complete. 2024-12-12 23:46:39.163 | NQZ24_FUT_CME 5000 Volume #12 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:46:39.175 | NQZ24_FUT_CME 5000 Volume #12 | Chart data loading complete. 2024-12-12 23:46:39.179 | NQZ24_FUT_CME 2 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:46:39.213 | HD Request # 1 | Receiving Intraday data for NQZ24_FUT_CME starting at 2024-12-12 21:59:59.188000 2024-12-12 23:46:39.218 | Socket (1) | CloseSocket call. 2024-12-12 23:46:39.218 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:46:39.284 | NQZ24_FUT_CME 2 Min #1 | Chart data loading complete. 2024-12-12 23:46:39.349 | Socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:46:39.349 | Socket (1) | Closed. 2024-12-12 23:46:39.572 | Mapping ESZ24_FUT_CME to ESZ24. Service code: cme 2024-12-12 23:46:39.573 | Added historical Intraday data request for ESZ24_FUT_CME to the queue. 2024-12-12 23:46:39.573 | Intraday data recording state for symbol ESZ24_FUT_CME is set to download 'Pending'. 2024-12-12 23:46:39.573 | Triggering next historical data download in queue. 2024-12-12 23:46:39.671 | Historical data download thread signaled to stop. 2024-12-12 23:46:39.671 | HD Request # 1 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * 2024-12-12 23:46:39.672 | HD Request # 1 | Received 1463 Intraday data records from 2024-12-12 21:59:59.188000 to 2024-12-12 23:46:35.565000 (106.6 minutes. Delay: 4.1 seconds) and wrote 0 records for NQZ24_FUT_CME 2024-12-12 23:46:39.672 | HD Request # 1 | Completion time: 1s. 2024-12-12 23:46:39.672 | HD Request # 1 | Intraday data download complete for NQZ24_FUT_CME. Unique request ID: 1 2024-12-12 23:46:39.672 | Removing historical data download ID 1. 2024-12-12 23:46:39.672 | Real-time Intraday chart data file updates started for NQZ24_FUT_CME 2024-12-12 23:46:39.781 | Opened cached Intraday file: C:\SierraChart\Data\NQZ24_FUT_CME.scid. Thread ID: 13820 2024-12-12 23:46:39.781 | Intraday chart data file opened for NQZ24_FUT_CME 2024-12-12 23:46:39.781 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-12-12 23:46:39.781 | 2024-12-12 23:46:39.781 | Historical data for NQZ24_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-12-12 23:46:39.857 | HD Request # 2 | Downloading Intraday chart data for ESZ24_FUT_CME to the file ESZ24_FUT_CME.scid. Service: cme 2024-12-12 23:46:39.858 | HD Request # 2 | Download start date-time: 2024-12-12 21:59:59.000000. File last date-time: 2024-12-12 21:59:59.510000 2024-12-12 23:46:39.858 | HD Request # 2 | Using server: ds32.sierracharts.com port 10149 2024-12-12 23:46:39.859 | Socket (1) | Creating socket. 2024-12-12 23:46:39.859 | Socket (1) | New receive buffer size: 0 2024-12-12 23:46:39.859 | Socket (1) | Connecting to IP: 67.214.125.3. 2024-12-12 23:46:39.924 | Error reading records from Intraday data file. Error: Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * 2024-12-12 23:46:40.014 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. 2024-12-12 23:46:40.082 | NQZ24_FUT_CME[M] #2 | Chart data loading complete. 2024-12-12 23:46:40.169 | 2024-12-12 23:46:40.169 | Teton CME Order Routing | Firm: Dorman/Stage5 2024-12-12 23:46:40.171 | Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 2024-12-12 23:46:40.286 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. 2024-12-12 23:46:40.290 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2024-12-12 23:46:40.290 | DTC Client socket (2) | New receive buffer size: 0 2024-12-12 23:46:40.290 | DTC Client socket (2) | Connecting to IP: 208.185.224.130. 2024-12-12 23:46:40.424 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-12-12 23:46:40.424 | HD Request # 2 | Sending historical data logon request message. 2024-12-12 23:46:40.432 | Teton CME Order Routing | Network connection to server complete. 2024-12-12 23:46:40.432 | Teton CME Order Routing | Starting socket receive thread. 2024-12-12 23:46:40.432 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none 2024-12-12 23:46:40.591 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-12-12 21:59:59. Record interval: 1. Symbol: ESZ24 2024-12-12 23:46:40.685 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. 2024-12-12 23:46:40.759 | HD Request # 2 | Decompressing data. 2024-12-12 23:46:40.916 | Teton CME Order Routing | Setting DTC encoding to Binary VLS 2024-12-12 23:46:40.916 | Teton CME Order Routing | Sending logon request message. 2024-12-12 23:46:40.919 | HD Request # 2 | Receiving Intraday data for ESZ24_FUT_CME starting at 2024-12-12 21:59:59.510000 2024-12-12 23:46:40.921 | Socket (1) | CloseSocket call. 2024-12-12 23:46:40.921 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:46:40.921 | Historical data download thread signaled to stop. 2024-12-12 23:46:40.921 | HD Request # 2 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart\Data\ESZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * 2024-12-12 23:46:40.922 | HD Request # 2 | Received 796 Intraday data records from 2024-12-12 21:59:59.510000 to 2024-12-12 23:46:38.883000 (106.7 minutes. Delay: 2.0 seconds) and wrote 0 records for ESZ24_FUT_CME 2024-12-12 23:46:40.922 | HD Request # 2 | Completion time: 1s. 2024-12-12 23:46:40.922 | HD Request # 2 | Intraday data download complete for ESZ24_FUT_CME. Unique request ID: 2 2024-12-12 23:46:40.922 | Removing historical data download ID 2. 2024-12-12 23:46:40.922 | Real-time Intraday chart data file updates started for ESZ24_FUT_CME 2024-12-12 23:46:40.974 | Opened cached Intraday file: C:\SierraChart\Data\ESZ24_FUT_CME.scid. Thread ID: 13820 2024-12-12 23:46:40.974 | Intraday chart data file opened for ESZ24_FUT_CME 2024-12-12 23:46:40.974 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-12-12 23:46:40.974 | 2024-12-12 23:46:40.974 | No download requests in the queue to start downloads for. 2024-12-12 23:46:40.974 | Historical data for ESZ24_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-12-12 23:46:41.103 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. 2024-12-12 23:46:41.112 | Socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:46:41.112 | Socket (1) | Closed. 2024-12-12 23:46:41.113 | Teton CME Order Routing | Received logon response. 2024-12-12 23:46:41.113 | Teton CME Order Routing | Server Name: SC DTC Server. 2024-12-12 23:46:41.113 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 2024-12-12 23:46:41.113 | Teton CME Order Routing | Connection error: No trade accounts assigned * 2024-12-12 23:46:41.113 | Teton CME Order Routing | Failed connections: 1 2024-12-12 23:46:41.115 | Teton CME Order Routing | Waiting for socket receive thread to end 2024-12-12 23:46:41.115 | DTC Client socket (2) | CloseSocket call. 2024-12-12 23:46:41.115 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-12-12 23:46:41.116 | Teton CME Order Routing | Disconnected. 2024-12-12 23:46:41.281 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-12-12 23:46:41.281 | DTC Client socket (2) | Closed. 2024-12-12 23:46:41.502 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. 2024-12-12 23:46:51.250 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. | Number times message previously added: 20 2024-12-12 23:47:01.031 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. | Number times message previously added: 18 | Number times message added: 3 2024-12-12 23:47:02.703 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 6. 2024-12-12 23:47:02.703 | Current selected Data/Trading service: SC Data - All Services 2024-12-12 23:47:02.838 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. | Number times message added: 1 2024-12-12 23:47:03.581 | Symbol settings MD5 received. Request ID: 6. 2024-12-12 23:47:03.581 | Requested symbol settings for service code scdataallservices. Request ID: 7. 2024-12-12 23:47:03.915 | NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. 2024-12-12 23:47:04.006 | SC Data - All Services | Disconnected. | Number times message added: 1 2024-12-12 23:47:04.009 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-12-12 23:47:04.077 | NQZ24-CME[M] #4 | Reloading chart. 2024-12-12 23:47:04.104 | Mapping NQZ24-CME to NQZ24. Service code: cme 2024-12-12 23:47:04.105 | Added historical Intraday data request for NQZ24-CME to the queue. 2024-12-12 23:47:04.105 | Intraday data recording state for symbol NQZ24-CME is set to download 'Pending'. 2024-12-12 23:47:04.105 | Triggering next historical data download in queue. 2024-12-12 23:47:04.105 | HD Request # 3 | Downloading Intraday chart data for NQZ24-CME to the file NQZ24-CME.scid. Service: cme 2024-12-12 23:47:04.106 | HD Request # 3 | Download start date-time: 2024-12-12 21:59:59.000000. File last date-time: 2024-12-12 21:59:59.188000 2024-12-12 23:47:04.106 | HD Request # 3 | Using server: ds26.sierracharts.com port 10150 2024-12-12 23:47:04.184 | Socket (1) | Creating socket. 2024-12-12 23:47:04.185 | Socket (1) | New receive buffer size: 0 2024-12-12 23:47:04.185 | Socket (1) | Connecting to IP: 64.152.155.17. 2024-12-12 23:47:04.223 | NQZ24-CME[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:47:04.225 | NQZ24-CME[M] #4 | Chart data loading complete. 2024-12-12 23:47:04.318 | NQZ24-CME[M] 5000 Volume #12 | Reloading chart. 2024-12-12 23:47:04.326 | NQZ24-CME[M] 2 Min #1 | Reloading chart. 2024-12-12 23:47:04.338 | NQZ24-CME[M] #2 | Reloading chart. 2024-12-12 23:47:04.369 | ESZ24-CME[M] 5000 Volume #3 | Reloading chart. 2024-12-12 23:47:04.438 | HD Request # 3 | Setting DTC encoding to Binary VLS 2024-12-12 23:47:04.438 | HD Request # 3 | Sending historical data logon request message. 2024-12-12 23:47:04.568 | HD Request # 3 | Requesting Intraday data. Start date-time: 2024-12-12 21:59:59. Record interval: 1. Symbol: NQZ24 2024-12-12 23:47:04.569 | ESZ24-CME[M] 5000 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:47:04.635 | ESZ24-CME[M] 5000 Volume #3 | Chart data loading complete. 2024-12-12 23:47:04.636 | NQZ24-CME[M] 5000 Volume #12 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:47:04.643 | NQZ24-CME[M] 5000 Volume #12 | Chart data loading complete. 2024-12-12 23:47:04.649 | NQZ24-CME[M] 2 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-12 23:47:04.665 | HD Request # 3 | Decompressing data. 2024-12-12 23:47:04.720 | NQZ24-CME[M] 2 Min #1 | Chart data loading complete. 2024-12-12 23:47:04.819 | HD Request # 3 | Receiving Intraday data for NQZ24-CME starting at 2024-12-12 21:59:59.188000 2024-12-12 23:47:04.822 | Socket (1) | CloseSocket call. 2024-12-12 23:47:04.823 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:47:04.889 | Symbol settings received. Request ID: 7. 2024-12-12 23:47:04.892 | Socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:47:04.892 | Socket (1) | Closed. 2024-12-12 23:47:05.182 | Mapping ESZ24-CME to ESZ24. Service code: cme 2024-12-12 23:47:05.183 | Added historical Intraday data request for ESZ24-CME to the queue. 2024-12-12 23:47:05.183 | Intraday data recording state for symbol ESZ24-CME is set to download 'Pending'. 2024-12-12 23:47:05.183 | Triggering next historical data download in queue. 2024-12-12 23:47:05.269 | Historical data download thread signaled to stop. 2024-12-12 23:47:05.269 | HD Request # 3 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart\Data\NQZ24-CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * 2024-12-12 23:47:05.270 | HD Request # 3 | Received 1474 Intraday data records from 2024-12-12 21:59:59.188000 to 2024-12-12 23:47:04.036000 (107.1 minutes. Delay: 1.2 seconds) and wrote 0 records for NQZ24-CME 2024-12-12 23:47:05.270 | HD Request # 3 | Completion time: 1s. 2024-12-12 23:47:05.270 | HD Request # 3 | Intraday data download complete for NQZ24-CME. Unique request ID: 3 2024-12-12 23:47:05.270 | Removing historical data download ID 3. 2024-12-12 23:47:05.270 | Real-time Intraday chart data file updates started for NQZ24-CME 2024-12-12 23:47:05.294 | Opened cached Intraday file: C:\SierraChart\Data\NQZ24-CME.scid. Thread ID: 13820 2024-12-12 23:47:05.294 | Intraday chart data file opened for NQZ24-CME 2024-12-12 23:47:05.294 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-12-12 23:47:05.294 | 2024-12-12 23:47:05.294 | Historical data for NQZ24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-12-12 23:47:05.300 | HD Request # 4 | Downloading Intraday chart data for ESZ24-CME to the file ESZ24-CME.scid. Service: cme 2024-12-12 23:47:05.301 | HD Request # 4 | Download start date-time: 2024-12-12 21:59:59.000000. File last date-time: 2024-12-12 21:59:59.510000 2024-12-12 23:47:05.301 | HD Request # 4 | Using server: ds28.sierracharts.com port 10149 2024-12-12 23:47:05.302 | Socket (1) | Creating socket. 2024-12-12 23:47:05.302 | Socket (1) | New receive buffer size: 0 2024-12-12 23:47:05.302 | Socket (1) | Connecting to IP: 67.214.125.5. 2024-12-12 23:47:05.466 | HD Request # 4 | Setting DTC encoding to Binary VLS 2024-12-12 23:47:05.466 | HD Request # 4 | Sending historical data logon request message. 2024-12-12 23:47:05.610 | HD Request # 4 | Requesting Intraday data. Start date-time: 2024-12-12 21:59:59. Record interval: 1. Symbol: ESZ24 2024-12-12 23:47:05.686 | HD Request # 4 | Decompressing data. 2024-12-12 23:47:05.772 | HD Request # 4 | Receiving Intraday data for ESZ24-CME starting at 2024-12-12 21:59:59.510000 2024-12-12 23:47:05.773 | Socket (1) | CloseSocket call. 2024-12-12 23:47:05.773 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-12-12 23:47:05.774 | Historical data download thread signaled to stop. 2024-12-12 23:47:05.774 | HD Request # 4 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart\Data\ESZ24-CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * 2024-12-12 23:47:05.774 | HD Request # 4 | Received 803 Intraday data records from 2024-12-12 21:59:59.510000 to 2024-12-12 23:47:05.952000 (107.1 minutes. Delay: -0.2 seconds) and wrote 0 records for ESZ24-CME 2024-12-12 23:47:05.775 | HD Request # 4 | Completion time: 0s. 2024-12-12 23:47:05.775 | HD Request # 4 | Intraday data download complete for ESZ24-CME. Unique request ID: 4 2024-12-12 23:47:05.775 | Removing historical data download ID 4. 2024-12-12 23:47:05.775 | Real-time Intraday chart data file updates started for ESZ24-CME 2024-12-12 23:47:05.798 | Opened cached Intraday file: C:\SierraChart\Data\ESZ24-CME.scid. Thread ID: 13820 2024-12-12 23:47:05.798 | Intraday chart data file opened for ESZ24-CME 2024-12-12 23:47:05.798 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2024-12-12 23:47:05.798 | 2024-12-12 23:47:05.798 | No download requests in the queue to start downloads for. 2024-12-12 23:47:05.798 | Historical data for ESZ24-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-12-12 23:47:05.852 | Socket (1) | Socket gracefully closed by remote side. 2024-12-12 23:47:05.852 | Socket (1) | Closed. 2024-12-12 23:47:06.100 | 2024-12-12 23:47:06.100 | SC Data - All Services | Connected to server complete. 2024-12-12 23:47:06.101 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-12-12 23:47:06.103 | Mapping NQZ24-CME to NQZ24. Service code: cme 2024-12-12 23:47:06.103 | Using symbol data fast lookup vector 2024-12-12 23:47:06.104 | Denali Data Feed | Starting real-time market data updates for: NQZ24-CME (NQZ24). ID: 1 Service code: cme 2024-12-12 23:47:06.106 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 2024-12-12 23:47:06.106 | Denali Data Feed | Requesting security definition data for: NQZ24-CME (NQZ24). ID: 1 2024-12-12 23:47:06.106 | Added historical Intraday data request for NQZ24-CME to the queue. 2024-12-12 23:47:06.106 | Intraday data recording state for symbol NQZ24-CME is set to download 'Pending'. 2024-12-12 23:47:06.106 | Triggering next historical data download in queue. 2024-12-12 23:47:06.107 | DTC Client socket (1) | Creating socket. 2024-12-12 23:47:06.107 | DTC Client socket (1) | New receive buffer size: 0 2024-12-12 23:47:06.107 | DTC Client socket (1) | Connecting to IP: 67.214.125.5. 2024-12-12 23:47:06.109 | Delaying start of download for NQZ24-CME. 2024-12-12 23:47:06.193 | Denali Data Feed | Network connection to server complete. 2024-12-12 23:47:06.193 | Denali Data Feed | Starting socket receive thread. 2024-12-12 23:47:06.194 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-12-12 23:47:06.385 | NQZ24-CME[M] #2 | Chart data loading complete. 2024-12-12 23:47:06.387 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-12-12 23:47:06.387 | Denali Data Feed | Sending logon request message. 2024-12-12 23:47:06.820 | Mapping ESZ24-CME to ESZ24. Service code: cme 2024-12-12 23:47:06.821 | Denali Data Feed | Starting real-time market data updates for: ESZ24-CME (ESZ24). ID: 2 Service code: cme 2024-12-12 23:47:06.821 | Denali Data Feed | Requesting security definition data for: ESZ24-CME (ESZ24). ID: 2 2024-12-12 23:47:06.821 | Added historical Intraday data request for ESZ24-CME to the queue. 2024-12-12 23:47:06.821 | Intraday data recording state for symbol ESZ24-CME is set to download 'Pending'. 2024-12-12 23:47:06.821 | Triggering next historical data download in queue. 2024-12-12 23:47:06.948 | Denali Data Feed | Received logon response. 2024-12-12 23:47:06.948 | Denali Data Feed | Server Name: SC Realtime Server. 2024-12-12 23:47:06.948 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-12-12 23:47:06.948 | Denali Data Feed | Successfully connected. 2024-12-12 23:47:06.948 | Denali Data Feed | Trading is not supported. 2024-12-12 23:47:06.948 | Denali Data Feed | MarketDepthIsSupported: 1 2024-12-12 23:47:06.949 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ24-CME -> ESZ24 2024-12-12 23:47:06.949 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ24-CME -> NQZ24 2024-12-12 23:47:07.119 | Denali Data Feed | Setting external service identifier for symbol ESZ24-CME to 183748 2024-12-12 23:47:07.119 | Denali Data Feed | Received security definition for symbol ESZ24-CME 2024-12-12 23:47:07.119 | Denali Data Feed | Setting external service identifier for symbol NQZ24-CME to 106364 2024-12-12 23:47:07.119 | Denali Data Feed | Received security definition for symbol NQZ24-CME 2024-12-12 23:47:11.096 | Requesting market depth updates for: NQZ24-CME if supported. NumLevels=100 2024-12-12 23:47:11.273 | Denali Data Feed | Clearing market depth for NQZ24-CME 2024-12-12 23:47:12.280 | HD Request # 5 | Downloading Intraday chart data for NQZ24-CME to the file NQZ24-CME.scid. Service: cme 2024-12-12 23:47:12.280 | HD Request # 5 | Download start date-time: 2024-12-12 21:59:59.000000. File last date-time: 2024-12-12 21:59:59.188000 2024-12-12 23:47:12.280 | HD Request # 5 | Using server: ds32.sierracharts.com port 10150 2024-12-12 23:47:12.281 | Socket (2) | Creating socket. 2024-12-12 23:47:12.281 | Socket (2) | New receive buffer size: 0 2024-12-12 23:47:12.281 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-12-12 23:47:12.455 | HD Request # 5 | Setting DTC encoding to Binary VLS 2024-12-12 23:47:12.455 | HD Request # 5 | Sending historical data logon request message. 2024-12-12 23:47:12.717 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-12-12 21:59:59. Record interval: 1. Symbol: NQZ24 2024-12-12 23:47:12.821 | HD Request # 5 | Decompressing data. 2024-12-12 23:47:12.987 | HD Request # 5 | Receiving Intraday data for NQZ24-CME starting at 2024-12-12 21:59:59.188000 2024-12-12 23:47:12.989 | Socket (2) | CloseSocket call. 2024-12-12 23:47:12.989 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-12-12 23:47:13.008 | Historical data download thread signaled to stop. 2024-12-12 23:47:13.008 | HD Request # 5 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart\Data\NQZ24-CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * 2024-12-12 23:47:13.008 | HD Request # 5 | Received 1478 Intraday data records from 2024-12-12 21:59:59.188000 to 2024-12-12 23:47:09.779000 (107.2 minutes. Delay: 3.2 seconds) and wrote 0 records for NQZ24-CME 2024-12-12 23:47:13.031 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-12-12 23:47:09.779000 2024-12-12 23:47:13.031 | Added 1 Time and Sales records to Intraday data file for NQZ24-CME after download. 2024-12-12 23:47:13.031 | HD Request # 5 | Timestamp of first Intraday data file record written: 2024-12-12 23:47:13.148000. 2024-12-12 23:47:13.031 | HD Request # 5 | Completion time: 1s. 2024-12-12 23:47:13.031 | HD Request # 5 | Intraday data download complete for NQZ24-CME. Unique request ID: 5 2024-12-12 23:47:13.031 | Removing historical data download ID 5. 2024-12-12 23:47:13.031 | Real-time Intraday chart data file updates started for NQZ24-CME 2024-12-12 23:47:13.051 | Opened cached Intraday file: C:\SierraChart\Data\NQZ24-CME.scid. Thread ID: 13820 2024-12-12 23:47:13.051 | Intraday chart data file opened for NQZ24-CME 2024-12-12 23:47:13.051 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2024-12-12 23:47:13.051 | 2024-12-12 23:47:13.051 | Triggering next historical data download in queue. 2024-12-12 23:47:13.052 | HD Request # 6 | Downloading Intraday chart data for ESZ24-CME to the file ESZ24-CME.scid. Service: cme 2024-12-12 23:47:13.053 | HD Request # 6 | Download start date-time: 2024-12-12 21:59:59.000000. File last date-time: 2024-12-12 21:59:59.510000 2024-12-12 23:47:13.053 | HD Request # 6 | Using server: ds26.sierracharts.com port 10149 2024-12-12 23:47:13.053 | Socket (3) | Creating socket. 2024-12-12 23:47:13.053 | Socket (3) | New receive buffer size: 0 2024-12-12 23:47:13.053 | Socket (3) | Connecting to IP: 64.152.155.17. 2024-12-12 23:47:13.076 | Socket (2) | Socket gracefully closed by remote side. 2024-12-12 23:47:13.076 | Socket (2) | Closed. 2024-12-12 23:47:13.264 | HD Request # 6 | Setting DTC encoding to Binary VLS 2024-12-12 23:47:13.264 | HD Request # 6 | Sending historical data logon request message. 2024-12-12 23:47:13.406 | HD Request # 6 | Requesting Intraday data. Start date-time: 2024-12-12 21:59:59. Record interval: 1. Symbol: ESZ24 2024-12-12 23:47:13.491 | HD Request # 6 | Decompressing data. 2024-12-12 23:47:13.580 | HD Request # 6 | Receiving Intraday data for ESZ24-CME starting at 2024-12-12 21:59:59.510000 2024-12-12 23:47:13.581 | Socket (3) | CloseSocket call. 2024-12-12 23:47:13.581 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-12-12 23:47:13.582 | Historical data download thread signaled to stop. 2024-12-12 23:47:13.582 | HD Request # 6 | Error writing historical Intraday data. Error writing record to the file C:\SierraChart\Data\ESZ24-CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk. * 2024-12-12 23:47:13.582 | HD Request # 6 | Received 806 Intraday data records from 2024-12-12 21:59:59.510000 to 2024-12-12 23:47:13.099000 (107.2 minutes. Delay: 0.5 seconds) and wrote 0 records for ESZ24-CME 2024-12-12 23:47:13.600 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-12-12 23:47:13.099000 2024-12-12 23:47:13.600 | HD Request # 6 | Completion time: 0s. 2024-12-12 23:47:13.600 | HD Request # 6 | Intraday data download complete for ESZ24-CME. Unique request ID: 6 2024-12-12 23:47:13.600 | Removing historical data download ID 6. 2024-12-12 23:47:13.600 | Real-time Intraday chart data file updates started for ESZ24-CME 2024-12-12 23:47:13.600 | Opened cached Intraday file: C:\SierraChart\Data\ESZ24-CME.scid. Thread ID: 13820 2024-12-12 23:47:13.600 | Intraday chart data file opened for ESZ24-CME 2024-12-12 23:47:13.600 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2024-12-12 23:47:13.600 | 2024-12-12 23:47:13.600 | No download requests in the queue to start downloads for. 2024-12-12 23:47:13.669 | Socket (3) | Socket gracefully closed by remote side. 2024-12-12 23:47:13.669 | Socket (3) | Closed. 2024-12-12 23:47:16.811 | Mapping NQH25-CME to NQH25. Service code: cme 2024-12-12 23:47:16.812 | Denali Data Feed | Starting real-time market data updates for: NQH25-CME (NQH25). ID: 3 Service code: cme 2024-12-12 23:47:16.812 | Denali Data Feed | Requesting security definition data for: NQH25-CME (NQH25). ID: 3 2024-12-12 23:47:16.812 | Mapping ESH25-CME to ESH25. Service code: cme 2024-12-12 23:47:16.812 | Denali Data Feed | Starting real-time market data updates for: ESH25-CME (ESH25). ID: 4 Service code: cme 2024-12-12 23:47:16.812 | Denali Data Feed | Requesting security definition data for: ESH25-CME (ESH25). ID: 4 2024-12-12 23:47:16.963 | Denali Data Feed | Setting external service identifier for symbol NQH25-CME to 42288528 2024-12-12 23:47:16.963 | Denali Data Feed | Received security definition for symbol NQH25-CME 2024-12-12 23:47:16.963 | Denali Data Feed | Setting external service identifier for symbol ESH25-CME to 5002 2024-12-12 23:47:16.963 | Denali Data Feed | Received security definition for symbol ESH25-CME |
| [2024-12-13 13:48:24] |
The issue with Rithmic is related to the following from your log: Rithmic Direct - DTC | Logon error received from server: permission denied
Refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure And then we are also seeing this error: NQZ24_FUT_CME[M] #2 | + Error reading record for update Intraday chart. Error reading records from the file C:\SierraChart\Data\NQZ24_FUT_CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
You are out of drive space. Refer to the following for how to clean up items from Sierra Chart, but you might want to look at other items you can clean up to increase your storage space: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
