Date/Time: Wed, 23 Apr 2025 03:04:33 +0000
Assistance Needed for Configuring Extended Rectangle Colors
View Count: 122
[2024-12-12 16:03:47]
User226793 - Posts: 174
Dear SC Team,
I hope this message finds you well. I am reaching out to seek your guidance on configuring the extended rectangle with various colors. Additionally, I would like to set up a hotkey for each color to streamline the process.
Could you please advise on the best approach to achieve this configuration? Your expertise and recommendations would be greatly appreciated.
Thank you for your assistance.
Best regards,
[2024-12-12 17:35:02]
John - SC Support - Posts: 39428
Follow the instructions at the following link:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
Note the sub-section at the end for how to create keyboard shortcuts for the Control Bar options that were setup.
