Date/Time: Wed, 23 Apr 2025 03:16:05 +0000
DOM and Chart Order Modification PnL PL 2720
View Count: 129
[2024-12-12 15:48:47] |
cesium - Posts: 129 |
Hello Support Team First, thank you for the quick and transparent communication regarding recent sierra updates and timer functionality. On v2720 and v2719, Order modification on DOM and Chart no longer displays new PnL while clicking and dragging. It is only after modification is sent (mouse released) that PnL for the order is updated. I recall on 2695 modification of orders via clicking and dragging showed updated PnL before sending modification. Has a setting been added to use this functionality? Thank you for your time |
[2024-12-12 15:57:35] |
John - SC Support - Posts: 39428 |
Refer to the following setting: Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
