Date/Time: Tue, 11 Mar 2025 07:37:49 +0000
Volume at price threshold alert v2 - problem
View Count: 225
[2024-12-12 13:39:59]
User785807 - Posts: 4
while using "Volume at price threshold alert v2" and setting "draw extension lines" and "draw extension lines until end of chart" to "yes", the lines for the last bar are not shown.
I suspect the problem is the extension lines for each bar start from the center of that bar and extends to the end of the chart. However, it seems the end of the chart is set to be the center of the last bar. Hence, for the last bar the starting point of the extension line and end of the chart are the same point, i.e. the center of the last bar, and thus there is not line drawn for the last bar.
End of the chart to be the center of the last bar makes sense for some studies like moving average, but for "Volume at price threshold alert v2" it seems to cause this issue.
Could you please suggest how I can solve this issue? (or maybe the root cause is something totally different that could be addressed.)
[2024-12-12 15:44:26]
John - SC Support - Posts: 38547
You are correct in that those lines are not drawn as the end of the chart is that last bar, so there is nothing to be drawn.
What exactly would you like to see?
[2024-12-12 16:20:45]
Thanks for confirmation.
I would like to see the lines (stacked imbalances) for the last bar, to start from the last bar and extend from the last bar to some point on the right, so it is visible that there is a line there.
[2024-12-12 18:00:23]
We have set this as a Feature Request. Just keep in mind that we can not say when we would get to any particular request.
[2024-12-13 01:36:33]
Glad to help improve the software!
