Date/Time: Wed, 23 Apr 2025 03:16:04 +0000
Volume Value Area for Bars can't highlight the area
View Count: 128
[2024-12-12 07:50:34] |
Kifutures - Posts: 6 |
Good day, I've been trying to get my Numbers Bar to have Value Area highlighted like in the attached screenshot (Capture 1) from Ninjatrader. In Sierra chart I've tried using Volume Value Area for Bars and I've tried setting different Draw Style in the Subgraphs, but I coulndt get a similar look to Ninjatrader's. Am I using a wrong indicator ? Your advise will very much be appreciated. |
![]() Attachment Deleted. |
[2024-12-12 15:21:13] |
John - SC Support - Posts: 39428 |
There is not a specific item that will make it look exactly like the image. But the "Volume Value Area For Bars" is the correct study to use. Try setting the Subgraphs draw styles to one of the following pairs and choose the one that works best for you: - Box Bottom Center - Box Top Center - Bar Bottom - Bar Top - Transparent Fill Rectangle Bottom - Transparent Fill Rectangle Top There are others that may work as well, you would need to try and see what works best for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-12 16:52:17] |
Thank you! Transparent Fill Rectangle Bottom & Top works well. Date Time Of Last Edit: 2024-12-12 17:23:29
