Date/Time: Wed, 23 Apr 2025 03:19:22 +0000
problem with sierra trand
View Count: 142
[2024-12-11 21:15:47]
barea - Posts: 1
Hi, I would like to know why the same SIERRA TRAND indicator appears differently if I open it in the dom or if I open it in the chart. I would need to have it in the dom in the same way as I display it in the chart. I attach images
imageIMG20241211114958.jpg / V - Attached On 2024-12-11 21:15:42 UTC - Size: 3.09 MB - 49 views
[2024-12-11 21:27:59]
Sébastien - Posts: 58
I think the visual difference comes from the bar spacing and the bar period that aren't the same on the DOM and on the chart.
By default the DOM use 1min bar period which is customizable, and the bar spacing is fixed and is not modifiable... unfortunately.
Date Time Of Last Edit: 2024-12-11 21:29:56
[2024-12-11 21:58:46]
John - SC Support - Posts: 39428
User217676 is correct, except for one thing. You can change the bar spacing on the DOM by using the Page Up/Page Down keys on the keyboard. Try changing the Bar Spacing to get what you want.
[2024-12-11 23:13:48]
Good to know ! Thanks John.
