Date/Time: Wed, 23 Apr 2025 03:04:36 +0000
Clearing firm to CME order routing process (how does it work)
View Count: 173
[2024-12-11 21:09:23] |
User873130 - Posts: 47 |
Is this correct? In order for for the buy or sell stop to get filled, the order goes first to amp and then the cme. So the broker knows buy/sell stops before it’s filled at cme. The orders are not routed directly from my computer to the cme
[2024-12-11 21:52:06] |
Sierra_Chart Engineering - Posts: 19307 |
No, the order goes direct to the exchange always. The broker is not involved in that. There is no interaction with any broker system at all except for end of day balance processing. It is a fully independent system connected to the CME. Brokers set parameters for your account, and all risk is managed by the Teton order routing system following those parameters. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
