Date/Time: Wed, 23 Apr 2025 03:09:23 +0000
27162719 (lag tested multiple times)
View Count: 174
[2024-12-11 16:25:18]
blt - Posts: 59
...hi SC Team
...not a problem but it could become
...the newest ver. 2719 is VERY MUCH under par to 2716 (in my case)
...order execution is lagging (almost 1 sec) as well as almost everything (menus; opening dialogs etc.) even in very low volume wise environment ; night sessions
...all compared with the same set-up (8 instances; 8 monitors)
...ver. 2716 works perfect !!! (probably I can stay on 2716 forever-love it)
...just wanted to let you know about it
...(my trading machine is superb and now a new one much better is about to get built)
...thank you
[2024-12-11 19:00:43]
John - SC Support - Posts: 39428
Version 2719 reverted to using the Operating System Timers by default. If 2716 was working well for you, then set the following option to "No" in order to have the system working like it was in 2716:
General Settings Window: Use OS Timer for Charts (Global Settings >> General Settings >> General >> Update Intervals)
Also refer to the information for the 3 time related settings above the above.
[2024-12-11 19:34:51]
blt - Posts: 59
I am on 2719--->snappy; perfect
Thank you
