Date/Time: Wed, 23 Apr 2025 03:12:52 +0000
Numerical ATR
View Count: 175
[2024-12-11 15:28:47] |
cmack1011 - Posts: 89 |
Can you please direct me to how I can display the value only of ATR on the main chart region (numerical value only, not the graph)? Thx |
[2024-12-11 17:52:34] |
John - SC Support - Posts: 39428 |
It depends on exactly what you want to see. If you just want the single value of the most recent bar, then use the "Text Display for Study" or "Text Display for Study From Chart" depending on where your ATR study is and where you want to display it. Refer to the following: Text Display For Study Otherwise, we would need more information on exactly how you want to view the information in order to point you to more specific information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
