Date/Time: Fri, 02 Oct 2026 15:39:37 +0000
Timer Management
View Count: 1219
| [2024-12-11 02:55:00] |
| User83524 - Posts: 49 |
I just updated to Version 2719. It would be helpful if the Timer Management setting under General Settings would be better defined as "OS Timer Management Enable." I had to review the Sticky Note to see which management system I was enabling. Selecting "No" would keep the SC timing . . Correct? Thanks!!!
| [2024-12-11 16:31:29] |
| John - SC Support - Posts: 48091 |
The setting for "Use OS Timer For Charts" defines whether you are using the OS timers (Yes) or the Sierra Chart timers (No). The setting for "Timer Management Enable" defines whether the following two items under it that start with (Timer Management) are used for the Sierra Chart timers. If this is set to "No", then the other two settings have no impact. If it is set to "Yes", then you also need for "Use OS Timer for Charts" to be set to "No" and then the two additional settings will affect the performance of the Sierra Chart timers. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
