Date/Time: Wed, 23 Apr 2025 03:19:23 +0000
duplicate a study subgraph?
View Count: 129
[2024-12-10 19:10:38] |
User763335 - Posts: 97 |
Is there a way to duplicate a study subgrpah, without duplicating the whole study? (ie duplicate the subgraph within a study and configure them differently) Thanks |
[2024-12-10 19:48:01] |
John - SC Support - Posts: 39428 |
Use the "Study Subgraph Reference" for this. Refer to the following: Study Subgraph Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-10 20:36:29] |
Not what I was looking for..This one creates another study to reference a subgraph of an existing study. I was referring to duplicating a subgraph "within" a study (without duplicating or creating another study)...so basically you'd end up with a single study with two identical subgraphs, each customized differently. Seems not possible and I'd just duplicate the study and rename them. Thanks |
[2024-12-10 20:41:21] |
The "Study Subgraph Reference" is the closest you will find to what you want. There is not a way to duplicate a Subgraph within a study.
