Date/Time: Fri, 11 Sep 2026 13:06:01 +0000
Alert Manager - add Study column
View Count: 447
[2024-12-10 17:42:46]
User365411 - Posts: 196
Please can you add a column with only to the name of the study that triggered the alert?
Having multiple alerts on multiple charts now it appear at the end (Source column) or middle ( Alert text column) of each row, so to check the name, the column and then the window use a a lot of space on screen.
TY
Date Time Of Last Edit: 2024-12-10 17:44:58
[2024-12-10 18:08:17]
John - SC Support - Posts: 47841
You can use the following setting to control what shows in the Alert Manager:
General Settings Window: Use User Defined Name Only in Alert Message (Global Settings >> General Settings >> Alerts >> User Defined Name)
