Date/Time: Wed, 23 Apr 2025 03:19:22 +0000
Auto-selection of Quantity value within the Quantity and Price modal
View Count: 162
[2024-12-10 13:47:30] |
PavelSavushkin - Posts: 2 |
Since version 2627, the field in the modal window "Quantity and Price" is no longer automatically selected upon opening. How can I set this field to be selected automatically? Steps to Reproduce: 1. Within the DOM window, place a limit order (either bid or offer, it doesn't matter). 2. Click on the quantity number in the set order to change the price or quantity. Note: the modal for `Quantity and Price` will open. Actual Behavior: In versions greater than 2627, the value of the `Quantity` field is not selected. Expected Behavior: The value of the `Quantity` field should be automatically selected, just like in versions 2627 and earlier. See the screenshot for more details. --- I was not able to use internal screenshot tool, since it does not capture the modals (or I did smth wrong). So, the image can be removed: https://www.sierrachart.com/image.php?Image=173383818631.png |
[2024-12-10 17:07:10] |
John - SC Support - Posts: 39428 |
Set the following option to "Yes": General Settings Window: Select All Text in Edit Control Upon Editing (Global Settings >> General Settings >> SettingsWindows) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-10 17:40:06] |
Thank you very much. That works perfectly!
