Date/Time: Wed, 23 Apr 2025 03:09:21 +0000
Converting Chartbook
View Count: 158
[2024-12-10 13:14:50]
User377189 - Posts: 215
While loading attached chartbook i got following message:
2024-12-10 08:12:09.441 | The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: D:\SierraChart\Data\OR_BreakOUT_MultiDOM.Cht *
Private File
[2024-12-10 17:05:45]
John - SC Support - Posts: 39428
Refer to the following:
Chartbooks (Workspaces): Opening Older Chartbooks
If this is not an older chartbook, then it must have gotten corrupted somehow. In this case, you would want to recover the chartbook from one of the recent backups that are made for them. Refer to the following in this case:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
