Date/Time: Mon, 15 Dec 2025 09:09:39 +0000
Bug in Trade Activity Log?
View Count: 293
| [2024-12-10 12:42:20] |
| User224654 - Posts: 23 |
Hello, I have the feeling that there is an error in the “Trade Activity Log”. The fourth row of the statistics always shows “Currency Value (C)”, regardless of what I have set in “Display Settings”. I seem to remember that this used to be different in an earlier version. In a previous version, the fourth row always displayed what was selected in the “Display Settings”, for example in my case it should be “Ticks ignore Quantity (t)”. The values are displayed correctly, depending on what I select under “Display Settings”: currency value, points, ticks. Only the fourth row does not change as described. Screenshot attached. Date Time Of Last Edit: 2024-12-10 12:49:46
| [2024-12-10 17:04:09] |
| John - SC Support - Posts: 43443 |
Refer to the following, particularly the second paragraph: Trade Activity Log: Profit/Loss Display Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
