Date/Time: Tue, 22 Apr 2025 22:35:31 +0000
Starting with ZEROth position in queue (Emulator)
View Count: 176
[2024-12-07 23:35:50]
DCSaba - Posts: 113
Thank you guys for keeping the Emulator in a good shape.
I have an observation that happens about 10% of the time and normally does not cause problems, but every now and then whne it does make a difference means a lot:
Here it is: WHEN THE TARGET's QUEUE POSITION FROM THE START SHOWS ZERO => It will EVER GET FILLED.
Unless price moves past Target, of course then it will get a fill. And this is what normally happens, but every now and then (when Target is placed REALLY WELL!) then it never will and kind of makes the difference between a Winner Trader and a Total Loss (as it comes back to the Stop).
So could you check out please why Sierra sometimesstarts out with showing ZEROth position in the queue?
[2024-12-19 16:00:05]
Sierra_Chart Engineering - Posts: 19305
Not sure why this happens but we made sure that the position in queue will not be less than 1.
[2024-12-19 18:10:42]
DCSaba - Posts: 113
That just might solve this!
Thank you so much. I'll test it.
Wish you happy holidays.
