Date/Time: Wed, 19 Mar 2025 03:34:47 +0000
Base Package and Teton
View Count: 168
[2024-12-07 10:08:02] |
User630519 - Posts: 5 |
Hi, Description of Base Package says "Base Packages support connectivity to Sierra Chart provided Data and Trading services only" Does this package support Teton? I don't need Denali (I will be using a different tool for data/analysis) I will be using Sierra for trade management. So the question is if Base Package is sufficient to be placing trades to Teton? |
[2024-12-07 19:40:51] |
Sierra_Chart Engineering - Posts: 18837 |
Yes you can connect, to Teton order routing using one of the Base Sierra Chart packages. However, you will not be able to access any real-time market data. It will only be delayed data. Is delayed data fine? For CME it will be 10 minutes delayed.
[2024-12-07 20:44:17] |
Yes delayed data is fine. What is the cheapest option to use the Web based trader with delayed data ? |
[2024-12-07 23:01:38] |
Service Package 3.
