Date/Time: Mon, 21 Apr 2025 13:05:51 +0000
Triggered Limit with Chase - Target
View Count: 331
[2024-12-07 08:47:04]
User925540 - Posts: 62
I see "triggered limit with chase" order type available as a stop order only, is it possible to add it as a target too?
It would be the same as "Target: Limit Touch Chase" but on the client side.
Thanks.
[2024-12-10 16:17:14]
Sierra_Chart Engineering - Posts: 19285
Limit Touch Chase is already a client side managed order.
[2024-12-10 17:00:51]
It does get sent to the exchange, even if the SC client is shutdown it will still act as a limit and get executed, right?
I'm referring to it not being activated when the client is not connected (Similar to Limit-If-Touched-Client for example).
The Triggered-Touched-Chase would serve that purpose, but it's only available for stops not targets.
[2024-12-10 20:08:53]
Yes:
We understand what you want. We will see.
[2025-02-27 02:48:08]
Hi
Just checking if there has been any thoughts on adding the "Triggered Limit with Chase" as part of targets (instead of being just with stops currently).
Thanks.
