Date/Time: Wed, 05 Feb 2025 17:04:45 +0000
Change default Settings for 2 targets
View Count: 82
[2024-12-03 22:21:31] |
User509751 - Posts: 1 |
hello there For the 2 targets with BE stop bracket order, there is a default configuration & quantity set for selecting 2 targets with BE stop bracket order When I changed the quantity & the setting that stops the the default breakeven function, then toggle to Simple Order, finally toggaling back to B3 Stop Bracket Order, it then starts to override my previous custom settings (quantity & breakeven funciton) How can I make sure that each time I toggle to 2 targets with BE common stop, it loads my custom settings? (The auto breakeven function is particularly important to me, I need to find a way to always not perform auto-breakeven when I switch from simple order to 2 targets with BE common stop). |
[2024-12-04 14:38:57] |
John - SC Support - Posts: 37753 |
A Trade Configuration is going to always load the information that is saved with it. If you want to change what is saved, then you need to setup the Trade Window the way you want and then save that configuration. You can overwrite the old file so the new configuration is stored or create a new configuration. Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
