Date/Time: Fri, 20 Sep 2024 02:57:01 +0000
simple candlestick bar chart transparently overlaid onto an existing TPO or Numbers Bar chart ?
View Count: 1216
[2014-09-11 21:51:54] |
User68474 - Posts: 201 |
I am aware that: "The following studies cannot be overlaid from one chart to another with the Study/Price Overlay study: •Volume by Price •TPO Profile Chart •Numbers Bars •Countdown Timer" However, conversely, can a simple candlestick bar chart be transparently overlaid onto an existing TPO or Numbers Bar chart? |
[2014-09-11 23:47:49] |
Only to a Numbers Bars chart.
[2014-09-12 05:25:08] |
Could a range bar of, for example, 4 ticks in ES, be "laid over" a 30 minute interval Numbers Bar chart?
[2014-09-15 18:33:59] |
Yes. Refer to help topic 28 here: http://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
