Date/Time: Wed, 05 Feb 2025 16:45:09 +0000
Chart Indicator Spacing
View Count: 113
[2024-12-03 14:04:25]
User528002 - Posts: 15
Good morning.
In some of my chartbooks, I have several charts that have three indicator panels below the main price action panel. For some of those charts, I'd like to adjust the height on those indicator panels to take up less room, less percentage of the entire window height.
How do I do that?
Many thanks.
And yet again, the more I use Sierra Chart, the more I absolutely adore it. Thank you for making it and for all your support.
[2024-12-03 17:33:23]
John - SC Support - Posts: 37746
If you are referring to regions, then refer to the following:
Working With Charts: Chart Window and Regions
If it is something else, then we would need to see an image of what you are referring to.
[2024-12-03 18:17:06]
Yes, this is what I was looking for, thank you.
What I was hoping was to be able to find the parameters that set the region height so that I could set it as a consistent default across all these particular charts where I want to adjust the regions. Is there a way to do that or can I only accomplish this manually?
You see, when I put in different studies on these charts and then want to go back to the studies that I've altered the regions for, it goes to the original default and I have to adjust the region heights manually again.
Any thoughts?
[2024-12-03 18:56:37]
There is no "default" setting for the regions. What you are seeing is how the system works in this regard.
