Date/Time: Wed, 05 Feb 2025 17:09:12 +0000
denali data vs interactive broker data
View Count: 130
[2024-12-03 11:31:51]
alin - Posts: 1
Hi! I sent you 3 screenshots, two from Sierra and the other from I.B.
I know that Denali is the best, but I was just curious about the candle from 18.00 hours (Romania time) or 11.00 (New York time), a red candle with top at $11 and bottom at 1$ in SIERRA, wich appears in I.B. just from $11 to $9.50, and in TradeZero is spanning also from about $11.50 to $9.50. Also other candles are different, but this one is VERY different.
I also applied the number bar studie in Sierra and this candle appears very odd, with total volume traded repeating itself with the value of 180 from $9.50 to $1, and also the difference between ask vol and bid volume at -121.
Also other candles have repeating values like this one.
So, the questions is: is this data in Sierra correct?
Thanks!
imageCapture SIERRA.PNG / V - Attached On 2024-12-03 11:10:51 UTC - Size: 166.63 KB - 39 views
imageCapture IB.PNG / V - Attached On 2024-12-03 11:10:58 UTC - Size: 284.62 KB - 37 views
imageCapture SIERRA number bar.PNG / V - Attached On 2024-12-03 11:28:45 UTC - Size: 502.29 KB - 34 views
[2024-12-04 04:14:21]
Sierra_Chart Engineering - Posts: 18285
You are comparing a NASDAQ TotalView symbol to a symbol in Interactive Brokers which is not NASDAQ TotalView data.
NASDAQ TotalView data is provided as is that we get from NASDAQ. It is accurate. We will not make any edits to it.
Regarding the repeating volume numbers with Numbers Bars:
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
