Date/Time: Wed, 27 Nov 2024 14:26:34 +0000
Chartbook Save
View Count: 919
[2014-09-11 21:47:03] |
User57562 - Posts: 98 |
1. Ctrl-B opens chartbook. Is there similar shortcut to close CURRENT book? 2. "Save any changes made to *.cht" would be better if seen ONLY if there have been changes. I have not found a choice. |
[2014-09-12 16:40:22] |
Re #1, I just found CC on toolbar. That works. Re #2, still interested. |
[2014-09-12 17:03:28] |
1. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar 2. This is not supported and there are no plans for this. It is inconsistent with design specifications. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-12 17:10:33] |
I don't know your design specs. I do know that computer cycles are wasted if I re-save unnecessarily. You're the bosses. |
