Date/Time: Wed, 04 Dec 2024 08:34:26 +0000
SC react slow
View Count: 82
[2024-12-02 12:22:38] |
Naive - Posts: 15 |
I just downloaded the new version sierra chart, but it seems the new version react very slow. Here is an example of GC, the situation is the same for other symbols. You can see when I wanted to modify the orders, the reaction takes more time to occur. It also took a longer time when I wanted to draw rectangles and zoom in and out in the graphs. https://www.awesomescreenshot.com/video/34213608?key=8dd5a7ffee23597999c6c41192423527 |
[2024-12-02 12:26:41] |
Naive - Posts: 15 |
Here is another link https://www.awesomescreenshot.com/video/34213959?key=8841c9c9387739a92a631041fd11ca0b |
[2024-12-02 17:23:50] |
User976943 - Posts: 39 |
Hi, I update to v 2712 and.. The same for me, Using HairCross is lagging. It is very slow to move. And also if I move an order in the chart is slow too. In version 2700 no Issues. Thanks |
[2024-12-02 18:03:21] |
John - SC Support - Posts: 36442 |
Most likely you need to adjust your "Chart Update Interval" to something higher than what you were using previously. Refer to the following: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2712 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
