Date/Time: Wed, 04 Dec 2024 08:42:06 +0000
Problem with downloading data
View Count: 30
[2024-12-02 10:31:48]
User953197 - Posts: 2
Hello
After logging into the platform, the chart will load completely and then the data will not be downloaded any further, the clock will run and the data can only be loaded manually after refreshing the chart.
On the computer I use at work everything works normally, the problem is on the computer I use at home after work after logging out of that device
Private File
[2024-12-02 18:56:44]
John - SC Support - Posts: 36442
If you are still having an issue, then we would need to see your Message Log from the computer where you are having an issue. Please follow these instructions to get us your log:
