Date/Time: Wed, 04 Dec 2024 08:42:13 +0000
Sierra chart realtimme
View Count: 73
[2024-12-01 12:45:16]
danielkoro - Posts: 3
Hello. I recently bought the integraded 11 service with real time data cme denali but in my chartbooks it still says DELAYED/REALTIME. It should be saying REALTIME only correct? For my friend its only REALTIME.
[2024-12-01 19:31:08]
Sierra_Chart Engineering - Posts: 17353
Yes you will be getting real-time data. Wait until the market opens, this Sunday evening.
If you are seeing delayed data let us know at that time.
Date Time Of Last Edit: 2024-12-01 19:31:27
[2024-12-02 00:40:39]
I dont know if im getting real time data or not but here it still says Delayed/Realtime i uploaded a screenshot. And by the way after purchaning the real time data my chartbooks are lagging VERY VERY MUCH wich was never the case before and it its not my pc.
imageusd.png / V - Attached On 2024-12-02 00:39:26 UTC - Size: 13.38 KB - 9 views
[2024-12-02 14:40:02]
That text in the Find Symbol window does not indicate whether you are getting delayed or real-time data. You should be getting real-time data now.
You can tell by looking at the data delay field which can be added to the Chart Header if it is not already there:
Working With Charts: Region Data Line / Chart Header
For performance issues, refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
