Date/Time: Tue, 29 Sep 2026 16:27:54 +0000
how to integrate custom streaming data into charts?
View Count: 726
[2024-12-01 07:06:20]
ijtraderji - Posts: 7
I have a set of custom data that is generated throughout the day. I would like to be able to chart this custom data in Sierra chart, use it with indicators, etc.
Is there any way to do that? I saw there is a way to use a text file of data, but does changing that text file automatically change the chart using that symbol?
Thanks for any advice.
[2024-12-02 17:48:38]
John - SC Support - Posts: 48056
When you import data into the system it is a one time action. Continued updates to that file do not update the data in the system.
For what you are wanting, you would need to create a custom .scid file that the system would read. Refer to the following:
Intraday Data File Format
