Date/Time: Tue, 15 Sep 2026 23:51:48 +0000
Buy/Sell Stop Shortcut at cursor
View Count: 944
[2024-12-01 01:23:20]
User969241 - Posts: 155
I am trying to place a buy or sell stop at cursor with the keyboard shortcut but I only see the option to place a limit order. Is there a way to do this?
[2024-12-01 19:29:40]
Sierra_Chart Engineering - Posts: 24877
Stop orders are supported. This is configured through the keyboard shortcuts:
Basic Trading and the Trade Window: Trading Keyboard Shortcuts
Trading Keyboard Shortcuts section.
Buy/Sell Stop at Pointer Price
To access this functionality you must update Sierra Chart to the current version. Instructions:
[2024-12-01 20:49:13]
I am not sure if I am missing something but I need a BUY and SELL stop in the shortcuts. I see buy limit and sell limit but not a buy stop/ sell stop. See attached for what I see in the shortcut menu. I have also attached what I use now in my right-click short cut menu that I am trying to get into the keyboard shortcuts.
imagesc2.png / V - Attached On 2024-12-01 20:48:51 UTC - Size: 8.56 KB - 165 views
imagesc1.png / V - Attached On 2024-12-01 20:48:57 UTC - Size: 9.03 KB - 144 views
[2024-12-02 01:31:12]
Now you want to submit a buy or sell stop order by a keyboard shortcut? At the current price level you are pointing at in the chart?
This is supported, but only in newer versions of Sierra Chart.
Date Time Of Last Edit: 2024-12-02 01:31:24
[2024-12-02 14:14:38]
Thanks. I just downloaded the most recent version and I don't see the option . Where would it be?
[2024-12-02 19:19:36]
John - SC Support - Posts: 47903
In the "Keyboard Shortcuts" window under the "Trading Keyboard Shortcuts" are options for "Buy Stop at Current Pointer Price" and "Sell Stop at Current Pointer Price".
[2024-12-10 02:52:19]
We do not see that you are running the most recent version.
[2024-12-10 06:42:22]
Profile Trader - Posts: 182
With regards to Keyboard shortcuts for trading. After reading the instructions and documentation I don't see this function as an option (Please Confirm)
I would like to make Ctrl+1 to be used to buy 1 contract at market and Crtl+2 to buy 2 contracts etc and then Alt+1 to sell 1 contract at market.
It appears the only function to do this would be 2 separate keystroke shortcuts where you change size with one shortcut and then another keystroke to make buy or sell.
Am I missing something?
Doug
[2024-12-10 15:06:16]
You are not missing something. You are correct that if you want a specific quantity, then you need to change the quantity first and then enter the order. There is no direct support for a keyboard shortcut that contains a quantity and an order.
You could create a custom study that would do what you are wanting. Refer to the following:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
